29DC after hitting rev limiter ?
studio54
70
32
Hello,
I was doing some WOTs on expressway and despite having taking the habit to shift at 5800-6000, this time I was enjoying the WOT and didn't take attention and hit rev limiter in 3rd gear at around 170+kph and 7000 rpm for one second (I sometimes hit the limiter in 1st or 2nd with no problem). It backfired during the rev limiter phase like it does normally cause I have the shiftbog tq limit 2048 option ticked in MHD which turn the stock soft limiter into a kind of hard limiter, so when rev limiter is hit, it backfires multiples very fast in a row until let off.
A long medium curb was arriving when I let off, so during the curb I wasn't on throttle, when I wanted to give it back after the curb, then the car was acting like it has a misfires and sound horribly throatier/weird or something.
No CEL.
I stopped on a parking and idle was bouncing a bit from 600 to 800, so I stopped the engine and restarted, then it was all fine again, stable idle and continued to WOT without any issues (while not hitting rev limiter in 3rd :D ).
When back home, I could read codes, and 29DC was in the history list.
Car was running a 1/4 tank, with a kind of E30 mixture. It's my week-end car, sometimes not driven for 2 weeks.
I give those details cause I know E85 sitting long time is bad and could mess with water/humidity and with 1/4 of tank maybe LPFP pressure is not top notch ?
(and sometimes the devil is in the details..)
Is 29DC exclusively related to injection/injectors and/or fuel (LPFP/HPFP) ? or could it be related to spark/coils too ? or tune (self custom) ?
(Any chance the DME could trigger the 29DC when STFT maxed out for example ?)
I know it will be difficult to diagnose without logs at first, but I will try to investigate/log and reproduce ASAP, what's important to log for this problem ?
Thanks all
Reactions: 2aesthetic4me
SlowE93
1,832
Just a plane ticket away !
E93
Hello,
No CEL.
Thanks all
Sounds like it may have misfired from slamming limiter ?
I would not try to reproduce, I would try to avoid doing it again 🙄
Reactions: studio54
studio54
70
32
I think it felt the same as misfires cause when 29DC is triggered, one or multiples injectors seems to be disabled until restart from what I read online.
I already had misfires in the past when one of my coils was bad, and I got a CEL + a misfire code with the specific cylinder number concerned. This time is different, no CEL, just 29DC, it's an injection cutout, however the DME did not precised which injector which point it might a general problem with fuel starvation (will check low and high fuel pressures in log) or maybe I need to revise my fuel scalar tables with STFT that I will log to see it maxes out.
I cannot count times I hit rev limiter these last years (1st, 2nd or even 3rd faintly though, this time 1 second :/ ), that's why it's surprising me, made me believe there is probably something that might be wrong : fuel mixture, injector(s), LPFP or HPFP, tune.
Or it could be like you said as well, maybe the rev limiter phase is asking too much fuel speaking, and DME triggered the 29DC.
What to log ?
Fuel mode, LPFP/HPFP, STFT/LTFT, AFR should be ok?
Kay
Figure what out ?
You hit limiter in 3rd and injector shut down too ????
I got this code today for the first time but i did not hit the limiter. I did add e85 today, something I haven’t done in a while. I wasn’t sure if it was the e85 or the limiter causing this.
studio54
70
32
I know this is a bit old, but did anyone figure this out?
Hello,
No, but it didn't happen again, and as recommended by SlowE93, I didn't trigger the rev limiter as such high speed and rpm. I think that because of the hard limiter too much fuel has been sent generating too much backfires and maybe the DME freaked out but not really sure, could also be my fixture that was too high in ethanol.
2aesthetic4me
15
Ă–hringen Germany
BMW E92 335i 2006
Hello,
No CEL.
Thanks all
I had the 29DC Error while hitting the limiter in 3rd gear. Right after it was chasing idle just like you had experienced. After deleting the codes and restarting the car it was running fine. About one week later, injector 6 died and left me running on 5 cylinders. Maybe look for the trim values for your banks and give your injectors a good look. The teflon gasket seemed to be broken on mine since i had a light fuel mist all over the area and the injector looked horrible after taking it out.
Greetings from germany
