Perhaps this information will be useful to someone building a timeattack based on a BMW e8x or e9x n54.
Body
Some carbon parts
1270kg. 54% front, 46% rear
Aero
Huge double element custom wing
Custom front splitter
Racelouvers fender vents
Suspension
KW competition 2A kit + kw top mounts front\rear
All custom made fully adjustable arms bearings
M3 sway bars front\rear
-5 front camber, -3.5 rear camber, 9 caster, front little toe out, rear minimum toe in
Solid engine, subframe, diff mouts
No rubber or poliuretane (except sway bar links)
Brakes
XYZ fron\rear
Custom brake balance regulator
No ABS
Engine, cooling
VRSF intake relocation kit
VRSF 7.5" FMIC
Custom side exhaust
OEM radiator
aux side radiator
side oil cooler
MHD
Wheels
Rota 18"x10" et20
250\280 slicks
Some video on IG https://www.instagram.com/anton.gultyaev/
Still much plans and work to do.
Body
Some carbon parts
Aero
Suspension
Brakes
XYZ fron\rear
No ABS
Engine, cooling
VRSF 7.5" FMIC
Custom side exhaust
OEM radiator
aux side radiator
side oil cooler
MHD
Wheels
Rota 18"x10" et20
250\280 slicks
