Radio knob no longer turning volume up or down, replacable?
MacBB55
80
Northern California
2004 BMW 525I
So i have a 2004 525i, the other day a friend of mine must have turned the knob really hard or something because when i came back to the car the knob was actually popped out of the panel to the point that as soon as i touched it it fell off and i had to pick it up and pop it back into the spot it goes but not it just spins and spins loosly. The screw behind the knob looks loose and flimsly sitting in the hole now but i dont know what it looked like before to compare, when you spin the button know it no longer makes the little clicking noise it did nor does the sound go up or down, i can still press the button to turn the radio on or off which is what makes me thing he may have somehow stripped it somehow or maybe i need to take it off again and tighten the screw that is behind it? i wanted to see what people thought before i commited to any way of fixing it, im thinking maybe i can replace button with a different one off one i find at a local pick n pull or part shop that is the same model, or is that too easy of a fix and im going to need to replace the whole panel?
LMB335is
301
189
FOB FL
13 335is
You're not going to find very much E60 specific info on this forum. There's a small 5 and 6 series sub forum but it's geared toward the newer stuff. Poke around on bimmerfest and e60.5post.com. You'll find a lot more model specific info there.
4,332
Sounds like your friend got a little wild and sent the knob. I think you can hold the power button in for a while and it resets the radio.
MacBB55
80
Northern California
2004 BMW 525I
I don't think resetting the radio will do much in this case to help anything lol, I have taken the knob off and it is the screw on the inside of the knob that is causing the issues, im planning on pulling one out of another bmw the next time I go down to pick n pull.
