NCS-Expert error when trying to read from any module!
Ron1776
14
St. Louis
2009 335xi E92 (JB4 & xHP)
INPA shows YES & ON, so I close it and open NCS Expert.
Load my profile, hit F1, then F3, select E89, hit OK, select CAS, hit OK and an error pops up:
FA-Fehler
COAPI-2021: Datenuebertragung zum SG gestoert IFH-0010:
Datenuebertragung interface/Steuergeraet gestoert CAS
COAPI-2021: Datenuebertragung zum SG gestoert FA_READ
COAPI-2021: Datenuebertragung zum SG gestoert FA_READ:
A_E65CAS
If I select NFRM, I get the FG(VIN) and FA(VO#) to populate but when I try to read the ECU, there's a different error:
Error in CABD! Look at CABI.ERR and ERROR.LOG!
Datenuebertragung interface/Steuergeraet gestoert FRM_70
CODIERDATEN_LESEN
Error.log file is attached. Car runs fine. I've coded many times but never seen any of this. HELP!
  • ERROR.LOG.txt
LMB335is
301
189
FOB FL
13 335is
FA-Fehler
A_E65CAS
CODIERDATEN_LESEN
First, is your JB4 off? Then I'd check your COMM PORT (latency) settings. Sometimes they change for whatever reason. Daten installed?
Reactions: Boorda and Ron1776
