keninger
Hello Everyone,
I would like to show you what I have been working on the past couple of months. It is called Log Dyno for Android and iOS. Log Dyno can measure Horsepower and Torque from your data logs. The first question which comes to mind with an app like this is how accurate is it? You have to remember Log Dyno is not only an app, but it also is a tool and it requires accurate data for accurate measurements. I have had multiple people visit a dyno shop and measure their cars on the dyno, and measure them with my app. The app turned out to be very accurate, in cases where the measurement was a bit off, turned out users put in the incorrect weight or gear ratios. After inputting the correct values, they were very surprised to see how accurate the app was. The accuracy of your measurement will depend on how accurately you input weight, gear ratios, environmental temp etc.
N54 335i
Log Dyno VS DynoJet
Calculated Shift PointsI would like to show you what I have been working on the past couple of months. It is called Log Dyno for Android and iOS. Log Dyno can measure Horsepower and Torque from your data logs. The first question which comes to mind with an app like this is how accurate is it? You have to remember Log Dyno is not only an app, but it also is a tool and it requires accurate data for accurate measurements. I have had multiple people visit a dyno shop and measure their cars on the dyno, and measure them with my app. The app turned out to be very accurate, in cases where the measurement was a bit off, turned out users put in the incorrect weight or gear ratios. After inputting the correct values, they were very surprised to see how accurate the app was. The accuracy of your measurement will depend on how accurately you input weight, gear ratios, environmental temp etc.
N54 335i
Log Dyno VS DynoJet
While measuring performance from a datalog is a great feature, there is another feature which I believe to be even better. Calculated shift points is a feature, where an algorithm analyzes your torque curve and based on that and your gear ratios, it will recommend shift points for each gear, which ensures that you are always putting down the most power available. These recommended values could be really useful while tuning auto transmission's shift points.
Interactive Measurements
After you get the result, you can name it and save it, so later on, you can load it back again and analyze it, modify values or email it.
Compare Measurements
You can compare up to 3 measurements, this way you can compare tunes, fuels, mods or just overall powerband as any measurements can be compared, they don't have to be from the same car. Here is a great example, a tuned 335i E92, and a tuned 325d E92, as you can see even though the diesel has nice torque down low, it can't hold it for long. (The car had issues though, but great for an example)
Compare Tunes
● SAE J1349
● STD
● DIN 70020
● ISO 1585
Power Units:
● WHP
● BHP
● PS
● KW
Torque Units:
● LB-FT @wheel
● LB-FT @crank
● NM @wheel
● NM @crank
Once you have your car set up, all you have to do is: open up your datalog, specify how much additional weight you had in the car, how much fuel you had in the tank (This is for calculating weight), environmental temp, pressure, and humidity is also required for correction factors, but there is an "Auto Weather" option which will pull the environmental values automatically if your log is a recent one.
A short video to demonstrate how easy Log Dyno is to use
Google Play Link
iOS App Store
User's Guide
If you have any questions or need any help, feel free to Email me!
Google Play Link
iOS App Store
User's Guide
