Jb4 S58 Step By Step Install
Mike @ XPH
Nov 18, 2016
468
98
Las Vegas
Note:
-We decided to wire the Bluetooth from the door instead of the firewall, it's easier to install and uninstall, it's also almost completely hidden.
-Im pleasantly surprised by how smooth map 1 is. Lots of power without any traction problems (RWD).
-Cant wait to put E85 and try the more aggressive maps :D
Gains are 80whp/100wtq on pump gas and up to 150whp/175tq on higher octane or E85 mixtures.
The ultimate tune for your S58 powered G80 M3 and G82 M4, the JB4 allows you to go from factory stock to full race and everywhere in between, with the push of a button on your steering wheel. The JB4 installs and removes quickly and includes many unique features not found in any other tune, including user-adjustable 1st and 2nd gear boost limiting, in-dash map switching, electronic wastegate control, ethanol fuel support, and built-in advanced CANbus based diagnostic tools. Installation is easy and completely removable with no splicing or cutting of factory wires.
Wirelessly connect the JB4 to your Bluetooth 4.0 compatible iOS, and Android device via the JB4 Mobile connect kit or to your Windows laptop with the BMS data cable. Both options allow you to record and analyze vehicle and tuning data, change JB4 performance maps, and update JB4 firmware as we release free newer versions with updates, more powerful maps, and new features under development. A separate JB4 Mobile app purchase is also required.
JB4 Tuner for S55 BMW M3 M4 M2 competition
S58 JB4 FEATURES & BENEFITS
• Gains are 80whp/100wtq on pump gas and up to 150whp/175wtq on higher octane or E85 mixtures.
• Improves 0-60 times and 1/4 mile times
• Preloaded with custom BMW tuning software and up to 8 maps for various fuel and modification levels
• The JB4 offers a lot more performance, functionality, and safety than your average performance chip
• Quick Plug & Play Installation
• Includes the rugged JB4 billet aluminum enclosure for protection
• CANbus OBDII integration offering unrivaled tuning features and performance
• Improved performance over non-integrated chiptunes
• Runs as smoothly as stock; this is how your vehicle should have come from the factory
• Compatible with all driving modes
• Fuel economy unchanged during everyday driving
• Compatible with JB4 Mobile for smartphone logging, tuning changes, and adjustment
• 91 octane fuel or better required for performance gains
• Ethanol (E85) compatible tuning maps
• Able to read/delete fault codes
• Not VIN locked and can be removed without a trace and resold down the road
• Made in the USA
• Free USA Shipping
• 5-year warranty
S58 JB4 Applications
BMW M3
• 2021+ S58 G80 BMW M3
• 2021+ S58 G80 BMW M3 Competition
BMW M4
• 2021+ S58 G82 BMW M4
• 2021+ S58 G82 BMW M4 Competition
What is a JB4?
The JB4 is a plug-and-play tune available for turbocharged vehicles. The JB4 tuner installs between your car's sensors, and its DME/ECU (computer) and manipulates vehicle performance through these connections making your vehicle much faster. While it's not the only tuning system that operates this way, the JB4 separates itself from the competition with much more advanced connection points and processing, including CANbus, fuel & spark control, Bluetooth to your smartphone, and a variety of innovative and advanced features not possible with any other system. BMS regularly publishes free mapping and firmware updates adding performance and features as ongoing development allows. In addition, the JB4 system is not VIN-locked to your vehicle and can quickly be removed and swapped between cars or resold at a later time. Often imitated but never duplicated, the JB4 has been the gold standard in plug-and-play turbocharged performance tuning for over a decade.
Reactions: Begood69
