How to move car around with no wheels?
NoGuru
1,206
592
Just North of Detroit
BMW 335is
I live just outside of Detroit MI, and I do not drive my 335IS in the Winter. I have a two car garage and usually just park it as close to the wall as possible.
This year I wanted to be able to remove the wheels and still get it close to the wall, problem is I am not smart enough to figure out how. My jack handle is probably 4' long, but I can jack at a slight angle and with about two feet or room, but it's a PITA.
I am betting there are some people around here that have great solutions to a simple problem.
So let's here your solutions to make this happen?
2,194
They make car wheel dollies so you can 'slide' the car into a tight spot but you still need wheels on the car.
I guess I don't see why you need to remove the wheels? Are you worried about flat spots or something?
Just buy some crap rims and tires wheels?
NoGuru
1,206
592
BMW 335is
Yeah Wheels dollies won't work for obvious reasons.
I want to remove the wheels for a few reason, I like to clean and ceramic coat them, I like to work on the car throughout the winter and often need the wheels off.
Also I want to store them in my basement.
Cheap wheels won't work if I need to remove them and can't....
2,194
Throw it up on jack stands then?
Taking a rim off is pretty damn quick with or without an impact. Why not get 4 beater rims and throw those on dollies. Roll it away and roll it out when you want to work on the car? Then jack, insert jack stand, remove wheel(s)?
NoGuru
1,206
592
BMW 335is
I see what you are saying, keep it on shit wheels on the dollies, then if I need to get to suspension I can still move it and then put it on stands.
That could work, only down side I see is keeping 4 shit wheels around without the wife asking why I have so much car shit :)
586
Getting cheap wheels makes having dollies probably obsolete. Except you can´t park close to the wall without them.
seb.apprenti
222
113
reunion island
335 i e92
the idea of getting four more wheels is the best for me.
we imagine that you find or manufacture four carts .... what do you do with them when you no longer need them? it will take up a lot more space and your wife will not be happy ;)
2,251
805
More effectively than a chassis dolly?
Dude that’s exactly what you want.
jack car up
Remove wheels
Sit car on dolly
Move it anywhere you like
Still say I’m MacGuyver 🤣
NoGuru
1,206
592
BMW 335is
Sorry Aus335iguy, maybe you are right, that might just be the way to go. I will dig into them deeper and see if they will fit my needs.
Okay you get a Macguyver 👍
TheFixer
493
352
Tennessee
2008 535i
I would buy some 4x4s and 6 heavy duty casters. Bolt them together to make a dolly just wide enough to sit on the rocker panels. Bolt three casters per side. You can then just unbolt it all when not using it.
NoGuru
1,206
592
BMW 335is
I like that Idea too. In the end I left it close to the wall and was still able to pull the wheels off. They went to the basement for ceramic coating.
