Just wanted to see if anyone knew if there was any difference between cheaper intakes (VRSF, BMS, ARM) and more expenive intakes (aFe, Injen). There is a good 400 dollar price difference and I just wanted to know if it was worth it.
Stock box plus Mr.5 mod…as good as any if not better bar a couple of nm torque at peak torque..plus better filtration, cooler IATs, no heat soak etc etc etc..
Built a hybrid DCI intake front hot side and rear cold side, both are right behind the headlights and have a heat shield on the cold side intake as it's close to the alternator which puts off some heat. I used a pair of huge skunk2 velocity stack cones, my inlets are full 3".
Have a aFe Momentum GT intake which worked great, but limited my options.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
