ETS Supra A90 Exhaust system
4,332
The Extreme Turbo Systems 2020 Toyota Supra Exhaust System is designed to be the highest performing exhaust system on the market. Our exhaust system features mandrel bent tubing for the best possible exhaust flow. This exhaust system is tig welded using only 304 stainless steel components including the exhaust hangers for maximum durability and reliability.
Maximum Flow and Performance Gains!
One of the biggest benefits of ETS 2020 Supra Exhaust System over our competitors is an optional 4.0" connection to the ETS Pro Series Downpipe, which increases flow area by over 21% at the exhaust connection. This is beneficial for both stock and aftermarket turbochargers.
Maximum Ground Clearance!
We've designed our y-pipe for maximum ground clearance by using 4.0" oval tubing, which improves ground clearance over a standard 4.0" exhaust system by over 35% while still maintaining the cross sectional area of a 4.0" exhaust system.
Exhaust Design Features
  • Aggressive 4.5" Slash Cut Brushed Exhaust Tips
  • CNC Mandrel Bent
  • TIG Welded
  • Symmetrical Design
  • 3.0" 304 Stainless Steel Tubing
  • Stainless Steel Exhaust Hangers
Exhaust Options
  • Dual Mufflers Version
    • (2) 10.0" Long x 6.5" Wide Stainless Steel Mufflers
  • Extreme Version
    • No Mufflers / Straight Pipe Design
Y-Pipe Design Features
  • 4.0" stainless steel oval tubing for maximum ground clearance with maintained cross sectional area.
Y-Pipe Options
  • Designed to fit factory and/or aftermarket stock replacement downpipes
  • Optional 4.0" connection for ETS Pro Series Downpipe Connection
Quality Assurance
  • CNC Mandrel Bent
  • Measured with CMM Probe for accuracy
  • Precision Tig Welded
  • Inspected and cleaned prior to shipment
  • Packed with expanding foam to ensure your exhaust system arrives safely
Install
  • Direct Replacement Design
  • Install can be done with basic hand tools in just a few hours.
31385
31384
31387
31388
