I have a 10/08 build date 2009 and it didn't come with an alarm and so I thought I would include some information I discovered along the way as it pertains specifically to the E93 since everything seems to be about the E90/E92.
The problem arises when I couldn't help but notice that my car never chirped when I locked it. The only way to know if the car was locked, is to be physically looking for the flashing lights. Even more irritating, the lights will only flash once and will not light up again with subsequent lock presses without unlocking first. So I did some digging around and found this retrofit kit: 65730427835
The problem, according to Tischer is that they don't actually sell that kit anymore. The mounting bracket and mounting plate are different and it does not come with an ultra-sonic sensor, otherwise they appear identical to the Sedan/Coupe kit: 65120403658
Evan told me that he could order these differing pieces from Germany, so here is a list of the parts which were included in my package:
61316932791 - Hood Sensor Bracket
61319119052 - Hood Sensor
65756949084 - Siren Bracket
65756949085 - Siren Mount
07119906163 - Sheet metal Screw
07129905542 - Hex Nut x4
07119902933 - Hex Bolt x2
The siren mount and siren bracket are the two pieces which are different, but I am not sure if they are actually needed over simply using the parts from the other kit. Regardless, those two parts as well as not having to buy the ultrasonic sensor.
