Well Gentlemen, After recently acquiring my 3rd E92 N54 it had one major flaw IMO TAN INTERIOR! Now this vehicle is going to built around 3 major factors.
Weight loss
Power
Handling
Phase 1 - Weight loss
I've picked up a set of Recaro SPGs and already have completely gutted the trunk and started on the rear seat delete. (Video coming up showing the process)
Ok enough of this boring stuff. Lets get into it.
Ok, so now what to do with this tan interior? Quick jump onto ebay showed me that if i where to buy all these pieces. (Dash/Carpets/Headliner/Pillars Etc) it would be in the thousands of dollars. But me being a pretty decent diy'er and have a painting background i figured lets do this. After much research in terms of products used and method. I've finally landed on a system that looks absolutely flawless. and 100% oem
without further ado. Some before pictures. previous owner thought it would look rad with some PARTIALLY! painted blue trim i then immediately replaced all trim with factory aluminum and a new red start button.
**EDIT** PROJECT IS NEARLY COMPLETE!
Waiting on the following items to be delivered.
Gray Alcantara Flat Bottom Wheel Yellow 12 Stripe
RTD Mini Shifter RAW
Hardmotorsports Yellow Door Straps
Alcantara Wrapped ABC Pillars & Dash
to get daily updates on the build follow DriverMod_N54 On IG
**EDIT** DIY VIDEO IS UP!
Bmw interior project by donald stevens,
Bmw interior project by donald stevens, on Flickr
As you can probably tell she was in pretty rough shape. but lets get into the afters...
After the driver side was complete time to go to the passenger.
was running out of sunlight so didnt capture any pics of the process.
All of this work was done for a total of $179.41 And about two full days of work. if you guys like what you see hop on over to youtube and subscribe to my channel for a full video explaining everything thats needed and what method was used! and all my future updates will be made on youtube! so if you like where this build is headed you know what to do!
https://www.youtube.com/channel/UCWf7aGTl1ezqRj2iA2Cq4EQ?view_as=subscriber
Weight loss
Power
Handling
