DCT to Manual on N55 135i (E82) - Wiring question
ganque
60
15
BMW 135i N55 DCT pure stage 2
Hi Everyone.
We are in the middle of the process of swaping out a DCT from a 135i E82 N55 car for a Manual Gearbox.
Trying to figure out the wiring process to make it work. Does anyone have any guidance? I can't find anything online about this method on N55 E series engines.
Thanks in advance,
ganque
60
15
Bump. Anyone?
@LMB335is do you know what wiring needs to be done?
I know that the CAS, FRM and DME need to receive signals, but can't find anywhere what pins are.
Sava666
174
36
LMB335is
301
189
FOB FL
13 335is
Shit, I think other than the clutch switch wiring, that's it as far as wiring goes AFAIK. 2TC needs to be removed from the VO and default code everything with the new VO. All the modules are the same, just coded differently
ganque
60
15
We are getting everything coded today.
Just to let everyone know. there are 4 things to be wired from the new clutch switch:
1 ground
1 wire to CAS for clutch remote signal
1 wire to DME for clutch remote signal
1 wire to FRM (that goes to 2 different FRM pins for reverse light switch)
There are some variants on which pins you are getting compared from a regular ZF6 to Manual Swap.
CAS PIN 41 was occupied by a signal wire from the auto trans. Depin this wire, wrap in electrical tape, etc. The new wire will require a new pin terminal
CAS PIN 2 requires a new pin terminal
DME PIN 31 requires a new pin terminal from connector X60001
FRM PIN 47 requires a new pin terminal
After this, Remove VO Code: "2TC" and Code all modules.
