It does skim over the other configurations a bit but the pinouts are listed and I believe they are very accurate. There is a thread on bimmerforums or somewhere else, and the guide there is completely inaccurate. There was a PDF floating around by an actual company, it may have been bavauto or someone like that. Their pin info was accurate and I used some of that to complete some of my tables. Sadly, I actually sold this setup before coding it in as I got an Avin unit instead so I ended up glossing over the last portion of the guide. The good news, I'm told the harness I made ended up working, so at least I know I did it right.
I just did this myself, and while it was very easy to repin for the combox I've run into a problem with my mic. I swear I pinned it right, but maybe not. Will check...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
