ABS and DME
Mar 14, 2017
418
346
Minot, ND
2010 135i
Does anyone know how integrated the ABS module is into the DME? For example, without the stock DME will the ABS module still work if it is receiving power? Or is it directly controlled with the DME like the rest of the DSC system?
1,267
771
You may try reaching out to Michael page on fb. He has a turbo ls1 E90 and would probably be able to tell you what does and doesn't need the dme to work
Mar 14, 2017
418
346
Minot, ND
2010 135i
I’ve been trying to find his contact info for a while. Michael Page is a pretty common name so I wasn’t able to find him by searching. I follow his post on bimmerpost and I know he has an IG but I don’t know what the name is. I would love to get him on the phone for a bit to discuss what he’s done and what I’m planning to do
dyezak
1,767
1,518
Plano TX
335is
Our DSC is used by race teams as a good stand alone stability control system.... so it can work without our DME. Probably only CAN messages.
Reactions: Rob09msport
1,267
771
Does that mean that it only uses braking to intervene? I thought the DSC system was a combination of braking and reducing engine power.
dyezak
1,767
1,518
Plano TX
335is
CAN output that the DME receives and responds by doing a throttle closure. The CAN message is unidirectional and the DSC doesn’t care or know if the DME received and complied...no real reliance there on the DME but they do “talk” and the behavior you mentioned exists.
1,929
664
I was pmed asking for a dump of my dsc rom because 09 actually contains new hardware not just software for improved e lsd. He is looking to convert thi m3 dsc and pump. If race teams use our dsc does that mean that we have same dsc as m3 but just different pump due to the larger brake fluid volume and piston area of m3 ?
dyezak
1,767
1,518
Plano TX
335is
No, this is a bit of a flip....but the non ///M DSC is actually more advanced than the M version. On the E series BMW still relied on a mechanical LSD for part of the stability control for the M3. The non-m cars have an open diff and as such have a different DSC that is more advanced to bring more control with open diff.
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
Yea, I can have the DME ignore DSC torque reduction requests and nothing complains...except your tires :grin:
ganque
60
15
BMW 135i N55 DCT pure stage 2
Hi jyamona, sorry for bringing back this post, but how exactly can you make the DME ignore DSC torque reduction requests? Is this only done by swaping the ///M DSC module? or is there any way to do this via coding?
1,929
664
So when we long press traction control and disable is their still some torque reduction ? Or would you be making it so single press dtc would function with brake intervention but not throttle.
ganque
60
15
The car I tested it on was stock DSC unit (335is) and just a DME change.
Is this something that can be done with TunerPro via an MHD custom map? If so, which parameter?
Jake@MHD
Nov 7, 2016
1,594
2,065
Philly
It was just a test, so it was constantly off (no matter the button) to prove it worked. Not sure what the best solution for release would be, as what I had would require a quick flash to re-enable the normal functionality.
scrllock
267
152
2011 335xi
Would this also allow one to forcefully prevent FLR as well? 2011 335Xi's seem to use the DXC_90_16 module, which just doesn't exist in the E89 chassis files apparently and so it's impossible to disable the e-diff, etc.
SJ_1989
368
299
Illinoisssss
2008 E90 335i
Similar topic, has anyone completely removed the ABS valve and had no issues with throttle reduction, limp modes, etc? I have a pedal box and brake bias adjuster so curious if I need to leave the valve electrically connected or I can remove it.
Levanime
Supporting Vendor
Nov 5, 2016
13
NorCal
there are DSC emulators that send constant fixed speed.
Or, JYamona can make file so DME does not care about DSC signal
Reactions: SJ_1989
