100WHP by installing an N52 exhaust cam in an N55.
mikeseli
140
81
2009 BMW 335i
From previous information:
N54 are
Intake 245deg 9.7mm lift
Exhaust 261deg 9.7mm lift
N55 is
Intake: 255* / 9.9mm lift
Exhaust: 261* / 9.7mm lift
I have the N53 cam specs saved somewhere, I'll see if I can find them.
When duration info is provided you need to state at what lift this duration is measured.
The N54 exhaust cam has 241 +/- 2 degrees at 0.005" lift on the cam, not on the valve.
The N52 and N53 exhaust cam has 254 +/- 2 degrees at 0.005" lift on the cam.
mikeseli
140
81
2009 BMW 335i
There were quite a few assumptions being made so I purchased an N52 cam and measured it against an N55 cam. The numbers help give a much better idea of how the cam swap will affect an N55. Quite a few of the assumptions in this thread are wrong... including some of my own. Post #67 mixes up the pictures. N55 is left and N52 is right. Post #107 has a lot of assumptions that don't seem to hold true. What I did find with my own measurements was that while the N52 and N55 share very similar exhaust cam profile in their respective engines, there are some other part differences that will produce much different profiles when the cams are swapped.
You can see the previously stated roller ratio of 1.64 can't be true (based upon my measurements). Resulting valve lift would only be 9.27mm. We know the exhaust valve lift for all three engines is 9.7mm so we can use that information to deduce the actual rocker/roller arm ratio for the N55 to be 1.72. It was hard to measure this ratio by hand because as little as 1/64" difference can swing the ratio from say 1.68 to 1.71. The math is simple though and the cam measurements are pretty accurate. 5.65*x=9.7 ==> x=9.7/565 ==> x=1.72. Do the same basic math for the N52 cam and you get a rocker arm ratio of 1.66.
This is important because the ratio play a direct roll in overall valve lift. Multiple the lobe lift provided by the N52 cam by the N55 roller ratio of 1.72 and you get a resulting valve lift of 10.03mm (5.83mm * 1.72 ==> 10.03mm). This is an increase of .33mm lift over stock N55 cam. The exhaust valve will also open earlier and close later. How much? That is not something I plan to try to figure out. It would require more measuring equipment and time than I have.
The general theory would be that more duration and lift out of the exhaust valve could potentially increase whp at high rpm while sacrificing a bit of torque down low. How much? certainly not 100whp. This kind of cam change would be chasing 10whp at best is my assumption. Maybe on an 800whp build you might pick up 50whp... That is reality of making small changes to the exhaust cam especially so with leaving the intake cam stock. Exhaust port restrictions are still there as well.
There are also a few things that need to be considered when doing the swap such as, Spring travel/bind, piston to valve clearance, hydraulic lifter preload/travel, torque on the cam ledge, etc. Most of which might be considered moot since it's a working swap. Stock springs have the travel from what's been measured by others... not too sure what kind of issue might pop up with the lifters.
here is a link to the pics and spreadsheet: https://drive.google.com/open?id=1R-GaBRBd7Gw6xIL5_GlULuCk3DTbD2O1
Maybe @CobraMarty or someone like @MOTIV Motorsport can be so kind as to share some opinions/speculation?
If you send me the N55 exhaust cam, I can measure duration directly off the cam itself with my setup. Also, if you have an extra N55 roller arm, I would like to measure it myself and compare it to a N54 roller arm.
Weehe
85
39
2011 335i
I have a complete N55 head in my garage I was planning to sell. Not sure if anyone is interested. I'll sell for cheaper in the name of measurements.
Bnks334
528
342
I was going to bring the head and each cam to a local machine shop to plot. Price is just not worth it for such a minimal mod. Unless someone wants to throw me a couple hundred bucks lol... It's only .3mm more lift-- a 3% increase. In regard to the roller, the math to deduce the ratio really is pretty simple. Not much room for error there unless my digital caliper is way off lol. I would send you a roller but I'd prefer to have the entire set to sell. the part numbers for the N55 roller is different if that helps support that it has a higher ratio. N52, N53, N54 owners might want to look at installing N55 rollers...
Within the context of this thread (PS2 turbo), it is speculated that EMAP is very high. Some are even saying there is exhaust valve float but I see no evidence of that... I would say is that earlier exhaust valve opening and increased lift can't really make up for poor exhaust flow. If true the above is true, the increased duration and overlap from the N52 cam would probably actually reduce top end power while gaining nothing from the extra lift. VANOS can only adjust in one direction from what I see as well so you can't negate the additional overlap.
Less overlap in these situations would actually be more desirable. Again this is just speculation based on what people have said recently about exhaust manifold pressure with a hybrid turbo like a PS2. The benefits of this cam would be seen more on freer flowing setups... ported head, bigger turbo, freer flowing exhaust manifold... Even at that, you would probably still be talking marginal gains from just swapping in an N52 exhaust cam. Like single digit whp...
doodlebro
78
43
X3
Hopefully our boy PureFthirty is taking notes, Bnks334 is showing how organization and actual data help understanding immensely.
But no we're all trolls lolololol.
mikeseli
140
81
2009 BMW 335i
That statement is false. You can open the exhaust valve 5-10 degrees earlier and close the valve at the same or 2-3 degree later and get lots of top end. It is all about reducing pumping loss and you can help this by opening the exhaust valve several degree earlier to achieve more power. This is where the duration on the exhaust cam comes into play.
Bnks334
528
342
I understand that, but, you're talking about an n52 cam swap not a custom cam... these are symetrical cams. If you're getting into lift sooner you're also going to be staying in lift longer, or am I off base with that statement?
mikeseli
140
81
2009 BMW 335i
All N52, N54, N53 cams have asymmetrical cam profiles, this was validated when I measured them. Even visually I can tell that they are asymmetrical, so I did not need to use any equipment to come to this conclusion. I'm 100% confident that the N55 cam is also assymetrical, based on the fact that 99+% of all cam profiles from all OEM since the late 90s are assymetrical.
The N52 and N53 exhaust cam has more duration than the N54 exhaust cam see post #162.
FYI, google "mikeseli cams" let me know if you have any other questions.
Reactions: ShocknAwe
Bnks334
528
342
Ok getting all defensive... not sure where to even start with this response. Not a single number you've posted thus far has been correct so I'm not sure what you've measured... all you've posted is assumptions that appear to be incorrect. And I think your comments now about symmetry are just as much of an assumption that you're supporting with name dropping. Not much worth googling from what I've seen so far...
I've posted the n54 cam profile, per frankenturbos plot, and the n55 profile, per the bmw academy docs (click my google drive link). Maybe someone like yourself with more experience can point out the difference in ramp rates? With the naked eye, and also looking at those cam graphs, I see pretty symmetrical curves and lobes. What exactly is it that you've seen and measured that you're alluding to?? Are you trying to say that the n52 cam wont increase overlap? That it has a less aggressive closing ramp or something? Just not sure what you're trying to say... and I dont have an n52 cam profile to look at that you might be basing your assumptions off of.
Yes, I think we covered already that n52 cam has slightly more duration than an n54 cam. 2* per bmw. No one needs to measure anything to know that much.
I dont have any info on the n53 cam but please share what you have... the point was that putting the n52 cam into an n55 to capitalize on the 3%/.3mm marginal increase in lift is also going to result in even more than that 2* additional duration. Duration and overlap not being good things within the context of the hybrid turbo ps2 and as evidenced by the dyno that saw no tangible gains at 6200rpm+.
Please provide more context to your post. We're all just trying to work through how we can take advantage of these part swaps.
CobraMarty
11
E92 328xi
Wow, where have I been?
Bnks334 and mikeseli contributions are very helpful.
I have 4 exhaust cams.
Used N52, N54, N55
New 'russian' sourced N52
I sent them out and had than all 'cam doctored'.
From all of this, what I find most interesting is the different part numbers for the N52 and N55 rockers. It would be great of the N55 rockers were higher ratio than the N52.
So if that is the case, I believe there is some merit to these power gains with using the N52 cam in the N55 engine.
This will add +0.3mm lift and +1* duration just from the N55 rockers with more ratio. Add that to the slight increase in the N52 duration, maybe you see +0.3mm exhaust valve lift and ?+5-7* duration.
This additional lift and duration using the N52 cam and N55 rockers would not add much peak power but will extend the powerband. That is exactly what is seen especially above 5000rpm. This makes for more power under the curve and more top end pulling power.
Yeah I call BS on +90-100 hp gains when the 'gain' is when compared to the stock drop off in power above 5000rpm.
If in fact that N55 rockers are 1.72:1 compared to the N52 1.66:1, I might just swap in a set of the N55 rockers into my N52 engine. Costs about $200 for +0.3mm lift and 1* duration on a N52.
I can post all my cam data sheets if need be.
Reactions: Weehe and Bnks334
CobraMarty
11
E92 328xi
Bnks334
528
342
I look at the torque curve, no more peak, just carried out further. This is good!!
The main issue with the comparison for me was that the "after" is about the same as most other ps2 pushing 23 psi at 5000rpm. That and the logs show a less than stellar "before" tune. So, we started asking questions about what the n52 cam might actually be doing. A few basics measurements and it's easy to see why an n55 cam wont be beneficial in other engines. And it's much easier to speculate how the n52 cam affect an n55.
CobraMarty
11
E92 328xi
The one other thought is the drop off in power after 4800rpm on the stock cam N55 is due to valve float.
With the N52 cam and N55 rockers and the additional 0.3mm lift, that brings the valve spring closer to 'binding' and this decreases the harmonicsof the valve spring and this in and of itself will decrease/delay valve float another 5-800rpm and thus extend the power curve.
Bnks334
528
342
Yeah I cant get on board with any of that... this resonates to that old thread with "headgames" on bimmerpost that was pure nonsense. If anything, the additional lift would move you closer to valve float. Pushing the spring further outside of its useable stroke means less control over the valve.
N52 cam is really just not a big change and the additional overlap is probably detrimental in this specific application. I'm going to roll with that unless someone has more info.
Weehe
85
39
2011 335i
Yeah there is no way we are getting exhaust valve float. I still doubt intake float from Headgames post. I also think opening earlier/closing later would hurt on a PS2 with high back pressure. Just think, you are trying to push against 50+psi of exhaust gas pressure. You want the exhaust valves to close asap before the intake valves open and you push exhaust gases into the intake. On a stage 3 turbo with minimal back pressure, yes it will help there.
CobraMarty
11
E92 328xi
IIRC the valve springs are the same as for the N/A N52.
Now in the N55 with more than stock boost, 20+ psi, without upgrading the valve springs, they will not be able to control the valve.
Weehe
85
39
2011 335i
So boost hits the bottom of the exhaust valve and causes it to stay open?
