ilikebigboost
13
BMW e92 335i Single Turbo
280,59kmh 174,35mph | 2018 | Henryk | e92 Single Turbo
ilikebigboost
13
I think if you're going to do this should only accept dragy 1/2 mile slips. Otherwise no way to confirm it's actually a standing half mile. Every event I go to has different rules, lengths, etc. Shift Sector is the closest to accurate.
You can check the rules of each event if its really standing half mile... regardless to that is that dragy is allowing slope to +-1% which is producing some differences... If you want to have the most accurate result you have to go with perfomance box and correct that time with db scanner to 0 slope which is common in europe :)
Terry@BMS
Jan 23, 2017
462
379
The max -1% slope variance rule I think is more reasonable than applying a correction factor to slope which may or may not be accurate. Next time you run test the dragy and your VBOX corrected times side by side in the same car and we'll see if they are different enough to worry about.
I used to love the performance box but compared to dragy it's really subpar despite costing 3x more. The box itself gives inaccurate traps (doesn't average over last 60'), inaccurate time to speed (puts a 1' roll out on them), half the time can't find satellites, sometimes doesn't save runs on the crappy SD card, etc.
Rcboosted2007
902
90
Parts unknown
07 335i
Agreed
ilikebigboost
13
I will test soon with new Setup :=)
Reactions: Terry@BMS
suspenceful
10 Second Club
Aug 1, 2017
559
591
75
2015 M3, 2008 135i, 2009 335i
168.91mph
2008 BMW 135i
Doc Race 6266 @ 27-28psi (~725whp)
Stock motor, manual transmission (6MT)
Weight reduction (3250lb with driver and half tank)
Log:
168.91mph
Stock motor with 6MT
81°F, 3335 DA, strong 30mph headwind (see hood in photo, pins coming soon :sweatsmile:)
Log:
View attachment 31265 View attachment 31266
Nice! I'm assuming you chose to go from a stop? I think NFZ lets you do it either way?
