I might be wrong but don't these come in the turbo install kit.Hi friends Do you know where to find spare gaskets for outlet 2 "? there is an equivalent at bmw? for the moment I have no problem, it is to put in reserve
I must express myself badly Sorry the pipes are installed and the o-rings too ... everything is fine the seals are not eternal and I would like to buy some before I get bothered where do you find those o-rings?I might be wrong but don't these come in the turbo install kit.
These are the O rings that go from the turbo to the outlet https://www.fcpeuro.com/products/bmw-o-ring-13717568030 These are the Vbands that connect them incase you wanted to replace them https://www.fcpeuro.com/products/bmw-clamp-11657558922I must express myself badly Sorry the pipes are installed and the o-rings too ... everything is fine the seals are not eternal and I would like to buy some before I get bothered where do you find those o-rings?
Ahhh. Yea those are most likely different. Sorry for the confusion. Just contact the company which you bought them from originally they'll be able to get you a spare set of o rings in the correct size.these are the O-rings for the original pipe on the 2 "pipe the O-ring is bigger no
non, pas le joint torique d'origine mais le joint torique de sortie 2 "Oh tant pis j'ai regardé ta photo un peu plus
