Slight grind from clutch going into 1st
335i_nick
98
43
I recently installed a Spec 3+, aluminum flywheel and a new slave cylinder on my ST 335.
I am experiencing this weird issue when going into first, MORE SO, with the wheel turned, ill get an awful grinding/screeching until I fully engage the clutch. It'll do it every now and then when the wheel it straight, but when its turned, it really gets loud.
I bled the slave cylinder probably 5 times, Almost positive there's no air in there. The clutch has only 500 miles on it.
Any ideas?
