Regular auto paddles to DCT paddles
Calamari_
32
What have you guys done for paddles? I ended up swapping the trim cover and paddles from the car i got my trans from and was wondering the best way to go about wiring them/getting them to actually function, currently getting a paddle shifter incorrect voltage code, would i still have to add resistors even when using the trim for the multifunction buttons that those paddles came with?
Tamaluko
13
California
Did your car originally come with paddles? If not you need the BMS paddle addition wiring harness. That's how I did it because my JBBE module didn't have the wires coming in and out of pins 35, 52 and 38, 22. I just went from x1880 straight to the blue 4 pin plug of the 6AT floor shifter with the BMS kit and from there to the transmission.
So you somehow need to get a connection from pins 2 and 4 of plug x1880 of the steering column switch to pins 5 and 1 of the x70020 plug of the transmission. You dont even need to go through JBBE module. You can bypass it completely.
If you are interested I can also find out what resistors I used.
Also make sure you re pin the paddles to pins 1 and 3 otherwise it will not work.
Calamari_
32
Ive been meaning to reply to this for a day or so, but yes my car did originally come with paddles (I believe, ill double check but im positive it did as it was auto originally, pretty much right after i got it i did a manual swap and now had to undo that to move to a DCT, I took the entire steering wheel trim and paddles off of the 135is parts car, paddles are already pinned properly (didnt have to mess with them) Ive already done the wiring in the DME box, my car is an 01/06 so i had to swap most of my modules inorder to support the DCT, all parts coming from the 135is, JBE, DSC, Trans, Shifter, Steeringwheel trim/paddles etc. I am getting a voltage incorrect code for my paddles (Havent looked in a while but im pretty sure im getting that code, Im more or less wondering if i can make it pretty much plug n play, im assuming i might need resistors in line with the paddles but im not understanding why they wont work out the gate with all the required/matching modules from that car
E90TommyB
37
Indiana
2007 E90 335i
I dct swapped about two years ago and I've also had paddle issues. My car is an august 2007 factory 6at build and I also swapped a bunch modules in the car to support the dct. I'm using LCI paddle shifters that I changed the pin out on to work and my upshift paddle works every time no problem but downshift paddle works intermitenly which is very annoying. I'll have to run codes with ista to see if I'm getting an incorrect voltage error but I may try adding resistors to the downshift paddle to see if anything changes.
Calamari_
32
I know I’m getting an incorrect voltage code at least so I suppose that’s my issue, I’ll most likely wire them up tonight, its weird just your up shift is working
Tamaluko
13
California
I really think adding resistors is the way to fix your issue @E90TommyB
I'm sure we've all seen the thread with this picture but I'll drop it here incase anyone needs it.
An issue I had at first was that I didn't notice the fact that it goes from pins 1 and 2 on the paddles but ends up on pins 1 and 3 on the steering wheel control buttons.
E90TommyB
37
Indiana
2007 E90 335i
I'm gonna give this a try. I'll have to find a female and male connector to make a little wiring harness. I hope this will solve my issue. Yeah I'm not sure why but my upshift paddle works flawlessly so I'm not gonna touch it.
