Precision turbo compressor wheel failure
trb1
13
Hi all.
Just lost my second precision 6062 to compressor wheel failure. First turbo at 15k miles and most recently at around 500 miles. Has anyone had this issue before with the billet wheels falling apart?
The first turbo precision claimed foreign object damage and I bought into it because I had my filter off a few days before I lost the turbo. However, the second turbo had a brand new filter and hasn’t been off since install.
Im not buying FOI for either of them now. It looks like material defect. Just want some input before I send this in again… wishing I went with Garrett at this point.
First turbo:
Second turbo:
SlowE93
1,321
E93
Hi all.
First turbo:
Second turbo:
Damn.....that's shitty !
One of my Associates that uses single turbo may chime in soon.
Reactions: JohnDaviz
trb1
13
Tell me about it. Lost it at the track today on my second heat. First time out this year. Talk about a total buzzkill.
SlowE93
1,321
E93
It does appear that something may have got in there though.....you said filter was on so I will believe it to NOT be foreign object....but does look like it so GL with Precision.
Reactions: fmorelli
trb1
13
I agree. My thing is, both of them have had a blade snap off. The foreign object that damaged the rest of the wheel was the damn compressor blade.
Also, I boroscoped my intercooler after the first failure and only found the single compressor blade.
675
I like my precision turbos and never have had any compressor wheel issues. Do you run a filter or turbo screen?
196
Is your filter mounted directly to your compressor housing inlet, or are you running some kind of intake?
trb1
13
I sent pictures to precision and their consensus is that it was either a bent shaft, unbalanced cartridge, side load, or the compressor housing came loose (spoiler: it didn’t).
Guess I’ll see what they have to say when the turbo gets delivered tomorrow. I was only running 15 psi. Side load doesn’t make sense with the wastegate pressure.
675
Seems like some manufacturer defects that you unfortunately ended up with. My buddy is running a 6466 on his built motor car and the compressor is a bit beat up and still makes good boost and doesn't grenade.
iminhell1
405
190
Do bear in mind that the BOV and WG spring pressures should be similar or tuned similar. If the gate is closed you can still overspeed the wheels and damage them. The excess pressure is just vented. The turbo isn't actually slowing down.
Verify the gate and how it's tuned. If you're simply relying on spring pressure (no Hobbs) then I'd recommend going to a lighter spring and investing in a good boost controller.
I've heard many stories about wheel failures. The ones that aren't foreign objects are almost always due to speed or surge. Low boost isn't common, and shouldn't be, for any damage. So that's why I'm thinking the gate is coming into play here.
trb1
13
40mm turbosmart wastegates. Spring pressure in the wastegate is 14 psi. Bov is 11 psi. I use a mac valve as a boost controller. I was just running a low boost map
675
Pretty common setup. Should not be an issue with your spring pressure or setup. Could be just bad luck. What bov are you running ? Precisions big downfall is probably being prone to damage from surge
trb1
13
Running a tial q. I honestly don’t know what I could have done to prevent surge at such a low pressure. I’ve taken every precaution to avoid issues like this
