Motiv re/flex
Reformatt
81
41
Houston
2010 335i E92
Not yet I’m debating I just recently installed their MHD flex sensor kit an whatnots. Still debating port injection it does look nice.
Supposed to replace a electronic boost controller and port injection controller
1,634
I hear it is the new “must have” unit if you have port injection. Integrates with DME logic. Works as if the DME was designed for PI. If/when I upgrade to PI I will definitely install MOTIV Re|Flex.
Jern54
311
Netherlands
E91 N54 335i
In for updates about this.
However I've ordered the split second controller because,
we know for a fact that the AIC delivers the fuel management that we need today, and if appropriately installed with a map reference on manifold it eliminates the issues of overspray with charge pipe pressure.
G3RSTY7
12
Vail pass
340i
I am. getting going on e85 tuning for my big turbo. Tuner thinks port injection isn’t spraying, but when i compare STFT to other tunes like pump gas i dont see a difference. How do my logs look, what am i looking for? I have a motiv reflex connected to hobbs switch so i know i need to make sure the switch is working and check wiring, is there a place to look for comprehensive info on the subject?
NoGuru
1,213
Just North of Detroit
BMW 335is
If you unplug the hobbs switch wire connector you can touch the two connection terminals inside the wire harness with some needle nose and the pump will turn on.
Reformatt
81
41
Houston
2010 335i E92
Any guys running the new motiv RE|Flex yet? Any feedback?
I did get the Reflex and then the ReflexV2 came out…so yeah I also bought the V2. Install was not difficult…unless your like me and can’t terminate wires very well. It is very much like the MotivFlex fuel kit the ground has to be properly grounded…
Anyway I finally installed the Reflex v2 along with the EOS intake manifold and BMP4.
I decided to have motiv provide the tuning, made sense to me it is their product. I cant thank Jake enough he put up with my crazy OCD self and fine tuned the tunerpro files, and with only one or 2 revisions he also had the MHD tune singing. 👍🏻 All in all pretty straight forward install and fairly simple..
