I am seeking help and guidance on how to run INAOS bin above 22psi with M-boost activated, let me start off with my setup and the log and setting I tried so far-
Built internal E60 N54
Factory fuel system with dual fuel pumps(factory EKP drive one pump and 2nd pump driven by PWM controller). Yes I need more fuel , that's another topic
Mboost activated
N20 installed
DCT with GTS M3 firmware.
19t turbo
1st Tune and log ( without Mboost)
Yes, the LPFP PWM need to be adjust for the LP issue , as far as I can see the target boost and actual boost within reasonable range , so I believe the PID working. Fuel trim will also need to be work on, but that's another topic
2nd TUNE - Log and setting ( with M boost)
Active Mboost by input MAP conversion setting, lower the Load Target/ AT ( logged and monitor load/psi relation) , start off ignition timing and WGDC(based) low until I get control of it , rescale the timing to provide more resolution, Load Target Per Gear and Boost Limited Multiplier Per Gear are all zero
Beside everything I mention above, everything else on 2nd tune remain the same ( VANOS, TQ LIMIT , FUEL SCALE, ETC) I basically transfer everything from 1st tune. However boost target on 2nd tune is not linear, something is limiting the output, I think it has to do with the scaling , I need help on what are the maps needed to rescale, then how about the Torque to Load model ? how is the DCT going to see the actual Torque value?
What is the rail pressure should be when 22psi at manifold?
Mboost activated
N20 installed
19t turbo
