I have installed a flex fuel sensor and an output converter that uses a true 0v-5v signal to the dme. I have read and come to understand that flashes designed for the motiv flex fuel module actually use 0.5v-3v for their output. Over and under that range being for failure modes. So currently while my converters built in Bluetooth shows shows 9% at a voltage of 1.1v, the dme thinks that means 26% ethanol content. I have the xdf for flex and am looking at the sensor voltage table. What should I change the voltages to?
Thanks
Tyler
Thanks
Tyler
