EPS Coding e89 variantencodierung_2 values
etropic
11
Looking to change the steering feel in comfort for 2-10- e89 35i.
Reading around looks like
and
Max-unterstuetzung
might be some valuable params.
Does anyone know what the variantencodierung_2 values represent? There are several model differences and many e89 options (current set to e89_var2).
Side note, VO says there is servtronic but I dont see that module separately.
3,592
Are you talking about programming the electric steering? I went looking for people digging in to this a few years back. There were some but no one had really figured it out. Hope you have more luck than I did! I will say that going to monoballs in the tension struts will make a significant improvement.
etropic
11
Right on.
Ya, was going to probably replace everything meaningful joint wise at least in the front to start with. I'm not as familiar with what's in the rear.
I'm going to play around with this settings and see what happens ;)
3,592
Right on.
Report back. Feel free to ask questions on your Z4 suspension - glad to help if I can.
Reactions: etropic
bosolanu
44
12
@etropic Wait, the e89 with EPS has 2 settings for the steering feel?
I am also very interested in customising the EPS, maybe we can figure something out. I do have the speed dependent servotronic active on mine if you want me to check something.
