If I grab the oem e90 front struts off my friend I'll write back, but I'll have to wait for spring compressors and a strut housing spreading too. Probably a week
It is a direct swap if RWD to RWD. I ran E90 BMWPS on my E82 (I wanted the higher spring rates). It was plug and play. Also, verts get a thicker rear spring (heavier car), so swapping to a non-vert might cause the rear to sit a bit higher.
Rent spring compressors from autozone or something. You can use a 3/8" socket adapter to spread the knuckle... Use two actually. 1 at the top and 1 at the bottom. Jam the square in and then twist it until it is wedged by its corners.
Thanks for the reply. Yeah I know the front spring are changeable from the e90 to the e82 of both are 6MT/RWD, but just to make sure are the struts changeable? Trying to swap out my ohlins so they can get rebuilt
You may encounter some visual styling issues as we resolve some upgrades to the forum.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
