F2X Con Rod bearing Code.
Dumaurier7
556
229
Hi all, I am currently gathering the required parts to do a crank hub upgrade along with the S55 oil pumps and sump swap, whilst there I'd like to do the con rod bearings too, I know the motor bearing combination codes are stamped on the crank but is there another way to get this information BEFORE pulling things apart so that I can have them in hand before I start? I don't want to have her down whilst waiting on parts!
Dumaurier7
556
229
Hmmm... No response so I guess the isn't another way ! guess I'll have to a bearing inspection and oil pump/sump upgrade before tackling the hub and con rods.
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
Videos I have seen dont suggest it is necessary to know that info prior. Shops take them apart and install them same day.
9krpmrx8
508
290
San Antonio, Texas
Bmw63
M235i
Yes, this is what I'm referring to but its only accessible when the crank case is dropped which SUCKS bigtime!
On the side of the block are codes like BBAAAB which refer to bearings, Im just not sure if they refer to mains or rods
Dumaurier7
556
229
Based on what I’ve seen the numbers are the crank mains and the letters refer to the connecting rods.
