Technical CAN sniffer
rac
341
204
135i ST
I have a AC control signal being sent from my syvecs at 10Hz with a frame id 608h, slot 2.
There is no signal conversion, it is simply y = 1*x with range 0 to 1. So probably sending through either 0 or 1 (off/on).
out of interest are you able to send through a screen shot of the maxxecu CAN output tables?
yuli8466
99
23
Recently got my Maxxecu N54 running. Currently trying get my A/C working, maxxecu can replicate the signal from DME to IHKA that will allow AC to come on. I need a sniffer log of the CAN A/C, working on on a 335i/135i so we can duplicate in the maxxecu. If anybody with a sniffer could help will highly appreciated. Please message me if u can help, thanks!!!
Hi I am planning running maxxecu in my N54, I write to maxxecu ,but they don't give the basemap
where do you get the base map ?
thank you
maxxecu is a good choice after comparing
STE92
224
83
E92
thank you
Your tuner will build a base map, he had mine running in like 30 mins.
