N54 Bucketed fuel pump upgrade - "Stock Series"
Horsepower Supported: Single Shot: 600WHP on Racegas ethanol blends below E50 525WHP on Ethanol blends above E50 Double Shot: 700WHP+ on Racegas ethanol blends below E50 650WHP on Ethanol blends above E50 Available Pump Upgrades: Primary: Walbro F90000295. No check valve means unsuitable as...
performancefuelingsolutions.com
N54 Bucketless Fuel Pump Upgrade - "Stock Series"
Horsepower Supported: Single Shot: 600WHP on Racegas ethanol blends below E50 525WHP on Ethanol blends above E50 Double Shot: 700WHP+ on Racegas ethanol blends below E50 (750 with 285 upgrade) 650WHP on Ethanol blends above E50 (700 with 285 upgrade) (If you need more power, we suggest the PFS...
Can someone explain the pros and cons of the two options..this is for an E89 35is with TTE500 turbos running on UK 98 RON fuel pls?
