Spoolers,
I'd like to introduce you to possibly one of the next best tuning platforms!
Check out the new 2017 Audi TTRS
The new TTRS will have the standard 2.5 Liter straight 5 cylinder engine producing ~400hp through the Quattro system and a 7-speed Dual Clutch gearbox!
Sprints to 60 in around 3.5 seconds out of the box. Major changes have been made to the engine since its last generation. The engine is now a full aluminum block, lighter crankshaft, along with 57 pounds of reduced weight.
How quick can it get up an go? Try 350lbs of torque at around 1700 RPM and 400HP at 5,850RPM. The newest change was made to the headers on the engine. The engine is using Audi’s variable-valve-lift-and-duration system on the exhaust camshaft. This system works similarly to Honda's VTEC System.
Audi is also introducing a new fueling option to the turbo-5. The engine is both Direct and Port injected to prevent carbon build-up and support 18-19psi stock!
You cannot deny that this Audi is performance vehicle out of the box. The new interior is meant to match the performance that's always at your finger tips.
Expected Base Price Line: $60,000
The pricing and performance puts it as a direct competitor with the BMW M2.
What do you guys think of Audi's new TTRS?
