yuli8466
99
23
Terrys 135i
VTT Built Motor
VTT GC 775whp
JB4 + MHD
Fuel it Stage 4
Phoenix Racing IC
Phoenix Racing IM with 750cc injectors
4th gear pull 5.41s 60-130, can't find graph
single 4th gear pull ?
and can 4th gear get 130mph in E90 335i?
Silentkiller335i
116
178
My goodness gonna add some nitrous?
Been there done that, nitrous doesnt help spool it much faster like you think it would.this motor just isnt very efficient. Doesnt pick up much power past a 50 shot and Ive sprayed up to a 200 pill through her. Then again im on a stock motor
Hmmm that's interesting. I geuss the best option for you to get some better spool would be ported head huh?
Super impressive from a stock motor though!
Reactions: Silentkiller335i
Silentkiller335i
116
178
Run a smaller more appropriate sized turbo is the correct answer. This turbo Flows 1200hp worth of air. And it will never see that power. I just did it to see what it could do. 64-67mm is perfect for stock motor and can be alot more usable then this 76mm
Yeah I agree that powerband that you got is so narrow. What is the peak boost you hit?
N54135iAT
37
17
BMW E82 135i N54
2nd, spools like hot garbage. 2-3-4 gear change. Makes 20psi at 5800 šŸ˜‚ and revved the car to 8100 on stock engine.
wow. Ive had a 70mm 1.15 ar reved that to 7950 rpm on stock engine before. Have a 6266 1.0 ar now. Car feels much better now and its enough for stock engine
Silentkiller335i
116
178
Do you have a road video from this run? Looks like a superbike graph or an error measurement caused by bridges.
No, i wasnt even trying to do 60-130. It was set on 1/4 on the street and i was messing with launch. Just so happen to run this time. Its a valid time on draggy i dont know what makes you think its an error or something, is it that hard to believe? You Obviously dont know my car
Brule
371
440
335i 2007 6spd manual
What sort of 7675 and what size exhaust?
Im about to make a 4 inch exhaust for mine.
I put a precision 7675 ls series turbo.96 rear with 3 inch exhaust. Its pretty lazy spooling similar or worse then yours.
Scorpstan
111
130
Just a question bro. I know Some graphes where this peaks are results from bridges.
But I don't know your mapping so it could be a big overboost at shifting what results in a punch of acceleration.
I know how hard it is I am close to you ;-)
What Speed do you have in this 1.4 run?
rominun
34
27
Socal
2010 135i DCT
Just did a 4.84 60-130 on my 135i at 32 psi. car was breaking up after 115 and i stayed in it lol. Built engine by me, 6766, with dct swap. Doc vu tuned. hoping to get a clean run at 32 psi with no breaking up.
